メインコンテンツにスキップ
2.2 GHz (Turbo Boost up to 3.4 GHz) もしくは2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467回答 すべてを表示
After replacing battery, It doesn’t work!
Replaced the battery last night, then it didnt work
  1. can not open mac without the adaptor
  2. as soon as i plug the adaptor, it reboot automatically???? Is this normal??
  3. checked the coconut : poor status, no charging
  4. check the system: no charging, need to be replaced now
  5. replace the old/original battery back, it works fine: good status, charging, ect.
  6. [BTW, BUT ALSO AS SOON AS I PLUG THE ADAPTOR, IT REBOOT AUTOMATICALLY?????? WHY]
  7. Now im using the new battery right, hope to find answers….
  8. already tried everything, like NVRAM and SMC reset
  9. already tried to charge the battery for hours……didnt work neither
== new battery status :
And I’m not sure if I would use the old battery back….. it’s swelling and doesn’t look safe now…..
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It seems you just got a bad battery, it can happen, ask for replacement including Coconut battery screenshot. A bad battery can cause issues such as the reboot, I wouldn’t worry about that for now. Coconut and the system have different reporting, that’s normal too..system gives green light and shows 100% when Coconut still shows charging is taking place.
このアンサーは役に立ちましたか?
スコア 4
5 件のコメント:
Ah..thanks
So now I’m basically giving up and wanna change the old one back..
Just not sure is it safe or no....
さんによる
@gemeny I was gonna answer yes, not a problem, but then I saw the pictures. No way, dispose of it properly but don't put it back at work, it might be dangerous for your Mac and for you too, it is likely it's exhaling unpleasant and unhealthy gas. You can run your Mac without a battery though if you need to.
さんによる
!!!!. I’m using it right now , i need to do the homework and write code, it will be super slow...
さんによる
unplugging the battery and mag-safe then reconnecting will cause a spontaneous reboot.
さんによる
an update...after replacing a second battery from ifixit, it works now
Thank you guys
さんによる
コメントを追加
回答を追加する
gemeny さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 235
