Black Screen and no chime
Ok so yesterday it was working fine but then today, the disc drive span but nothing. I got it to boot once but the after the shutdown and trying to start up again, nothing happened on the display.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 16
今までの合計 60
Have you done a smc and pram reset
Michael Youngs さんによる
yep already tried that and nothing happened
jimmysofat6864 さんによる
Okay, because you have no chime the next thing I would check is to see if your fan is spinning. So open it up and hit the power button. Fan spin is a good indication that your CPU is getting power and the computer is on. If there is no fan spin you are likely looking at a power fault on the logic board.
it appears the fan is spinning. its also worth noting that the battery isn't charging but I think thats because it wasn't charged in 4 years
