メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
Logic board not working
what can cause the logic board to just stop working?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
First off you need to check that its the logic board and not any of the components like dock or battery. Try your board in a friends case or Take the board out, check your connections and while you're there check the output on the battery. Use a multimeter on pins 1+4 should be 3.7mAh for a fully charged battery, but not working at about 2.2? If it's dead then replace it. Usually a battery will give warnings like freezing up, crashing, not holding charge for long.
If your battery is good then you need to check the dock connector for dirt/damaged pins etc that are stopping it from charging or being recognised. replace it or just that flex.
After that it gets a whole lot more tricky..
このアンサーは役に立ちましたか?
スコア 4
8 件のコメント:
i have another working 3gs that needs a backlight coil i tryed the battery from that in it and it still didnt turn on and i also swapped docks and still nothing
さんによる
Ok I've confirmed it's not that battery or the dock so it has to be the logic board how do I fix it? is there something on the board I need to replace?
さんによる
check the fuses near where the battery contacts are, also check connector 4 on your motherboard. then it's power ic
さんによる
sorry pollytintop could you explain a little more detailed?
さんによる
Jared, I think that pollytintop may refer to the fuses as shown on the pictures at this question Won't turn on after attaching to car charger
さんによる
3件以上のコメントを表示
コメントを追加
Water damage, drop damage, electricity damage (getting shorted out), old age, and many more reasons.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
ok my 3gs just stopped working out of the blue no drop water damage nothing what could be wrong i replaced the battery and still nothing
さんによる
not recognised in itunes? not charging? no display?
さんによる
all of the above
さんによる
コメントを追加
回答を追加する
Jared さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 2,857
