メインコンテンツにスキップ
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150回答 すべてを表示
Why wont my car crank?
Parked car at work, got done with work, all dash light came on normally, turned the ignition to start, nothing. Towed car home, replaced entire ignition switch assembly, let the car relearn, nothing. jumped the pins on starter relay starter cranked, replaced relay, nothing. Any Ideas????
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sounds like it must be open wiring between ign. switch and relay somewhere. If automatic trans it may be the interlock switches that prevent starting except in neutral or park positions (typically). I would try jiggling the shifter first to see if it will help get a complete circuit to your apparently good relay.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
David Lindorff さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 45
