メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
no LCD or backlight. tested two LCD panels, external monitor is good
i recently decided to make another pass at this 2012 MacBook pro which has been sitting in my drawer for some time. I have no history on the unit, it arrived as part of a lot of non-functioning MacBooks. no tripped moisture indicators, and the innards didn’t appear tampered with.
said MacBook will chime and boot fine, but never outputs display to the internal LCD. it’s obvious that the backlight isn’t illuminating, and the flashlight test yields no activity on the LCD itself. needless to say, uncountable SMC and NVRAM resets have occurred, as well as reinstalls of macOS. i have tested this on two separate LCD panels, the second is “known good” from a working machine. for what it’s worth, this test was accomplished by transferring the MLB to another complete MacBook, rather than simply connecting another display in place.
i have my normal routine for no-backlight-having MacBooks, but the no LCD is throwing me for a loop.
advice (other than genius bar, replace logic board, etc) is most welcome!
i have tested all of these points, none show 3v3:
following the board view, i also have no 3.3v at R1984, but i don’t know how to follow the trace to what i’m assuming is the other side of the board?
there appears to be some tomfoolery at the battery status connector (which has an SMC function as well)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
hmm, this does look like a logic board issue to me, sad to say. I’ll let the more experienced people do the talking though.
さんによる
yes i have surmised that it's a logic board issue. my hope is a short list of common points to check!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@reverendalc
check the display connector. Check for bend broken or corroded pins. Post some images of your logic board with your question. That way we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that.
Measure the connector and see if you have the voltages required to turn the internal display on.
このアンサーは役に立ちましたか?
スコア 1
18 件のコメント:
always pleased to see your replies old turkey. i've attached a photo of the LVDS connector and cable end. they both look very healthy.
さんによる
The cable checks out from an appearance standpoint. Still could be an issue with the cable or the connector on the Logic Board itself though.
さんによる
additionally, i've tested every pp3v3_lcdvdd_sw at and after U9000 with no satisfaction
さんによる
@reverendalc connector looks really good. Are you saying you do not have 3.3V on pp3v3_lcdvdd_sw?
さんによる
that is correct. i also added to my original post all of the points i've tested for 3.3v. i'm currently looking at the S5 which feeds U9000, and both pins 2 and 3 carry 3.3v into U9000
さんによる
13件以上のコメントを表示
コメントを追加
回答を追加する
Ronnoc Nailli さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 152
