Camera is making home button not work
Took the camera out to clean the speaker net since it was low, after assembling it all back the home button didnt work anymore as well as the camera, after i unplug the camera everything works normal, changed the camera already so it not the cam, what could it be?
Can you confirm that it was the front camera that you changed or the rear.
as you could have a damaged pin on one of the connectors or a component that has come loose when you disassembled the device.
A One Mobiles さんによる
