HDMI repair on insignia
How do I repair the HDMI port on my 42” Insigna flat screen..
この質問は役に立ちましたか?
この質問は役に立ちましたか?
clarence peska,
If your television is experiencing HDMI troubles including no signal and distorted video, see the Insignia NS-24ER310NA17 No Signal With HDMI problem page for possible causes and solutions.
First off we would need to know your TV’s exact model number. You also want to try other HDMI devices to see if it is your TV or the device (Firestick) that is at fault here. The HDMI ports are all connected to the mainboard so if it is your TV then replace your mainboard. If it is the Firestick then you will have to get a new one.
このアンサーは役に立ちましたか?
The model # for the Insignia tv is: ns32d220na8
@gabrielena31263 but what's your question? what repair do you need done? what is wrong with your TV?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 36
今までの合計 2,349
2 件のコメント
Can you go in more depth about what is wrong with it?
TechTalks さんによる
Yes I bought a Firestick and it seemed to blow out 3 of my 4 ports. I heard a small pop each time and the screen went blank.
Andrew g Ebel さんによる
