メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBLによるFlip ポータブルスピーカー第3世代の修理とサポートガイドです。
Speaker seems to “scream”
After playing music for a few minutes my speaker seems to “scream” than turn off even though it’s fully charged. The speaker doesn’t crackle but literally sounds like dragging long fingernails on a chalkboard, but with more intensity. It used to be an amazing speaker but ever since a month ago it’s been doing this. Not sure if JBL speakers are just trashed after time or if there’s a way to fix this but I’m all ears for your answers.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
5 件のコメント
Did you get this figured out? I can't even find anyone else that's having this problem besides us.
さんによる
Answers anyone?? Exact same problem. Screaching noise and turns off with full charge
さんによる
Does your battery look too big for its spot? I mean, when I took my speaker to pieces, the plastic part that covers the battery seems to compress it , as if the battery was bigger than it should be. I can't put it back together anymore because of the battery, which is too big. It might be a stupid question but does someone know if a battery can get bigger when you take it into a plane?
さんによる
I have the same issue, I would prefer if I could fix it than have to buy a new speaker
さんによる
Same here, screeching noises that sounds haunting and gets louder until I turn it off.
さんによる
コメントを追加
6件の回答
ベストアンサー
I believe I figured out what's happening, however I haven't been able to fix it.. the problem only happens at higher volumes due to the movement of the speaker itself inside the housing causing copper on copper contact.. this causes the screeching sound you hear followed by a short which turns the speaker off. Wrapping the wires didn't seem to help so if anyone else has any ideas..
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Has the connectors from the speaker to the housing changed or loosened in any way?
Can you tell (show us)m what you are referencing in the guides? JBL Flip 3
さんによる
コメントを追加
This Youtube video may be helpful, https://www.youtube.com/watch?v=RqYyeGMU...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
YouTube video was for bass buzzing, not screeching.
さんによる
コメントを追加
Soldered all the wire connections so I don't believe that's the issue. The arrow in the pic indicates the movement that occurs at high volume.. the copper ring on the inside seems to be coming into contact with something but I can't see what it is/get to it. At lower volumes that copper ring doesn't move so violently and therefore there's no screech? The wires appear to touch at high volume as well but I wrapped them and the screech continued
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Think the battery or the charger has gone bad. Try replacing the battery. https://youtu.be/sYtpdHWl7fc
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have same screech sound at higher volumes. Battery seems to die within seconds after recharging. Noticed that there is no screech when unit is plugged into charger with volume cranked up. So I believe it may be a bad battery. Interested in hearing others opinion. Thx
さんによる
コメントを追加
you change the battery , jbl is nothing happened distortion or rip the speaker in loud volume ,because it is their reference .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I always thought it was the speakers that handle the bass going out. I noticed it happens with mine when I play songs with bass or drums
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lagardner1999 さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 20
過去 30 日: 103
今までの合計 12,870
