Is SSD data safe during battery Replacement?
I want to change my MacBook Air battery. Will disconnecting the old battery cause loss of data on y SSD Drive?
Nope, your SSD will be safe and sound. Just make sure that the battery connector never touches any components on the logic board to avoid sparking and frying your board.
このアンサーは役に立ちましたか?
Aaron is right just wanted to add that you should always have a Time Machine backup anyway, even if you aren't doing any kind of repair.
That is very important too, if you have valuable data on your computer that you cannot afford to lose if something goes awry.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 65
