Screen turns black after 2 seconds of loading.
I have a Lenovo Flex 2-15 (it wasn’t on the list when i made this).
When I power it up, the Lenovo logo shows up with the loading circle for two-three seconds and then the display turns black. The actual laptop works but the fan starts spinning faster than usual. I have tried refreshing, factory restarting, safe mode and some other things to fix this but i have failed.
have you dropped it?? at some time??
Ramiro さんによる
explain last time when you are able to use your laptop and what make you fall into this error.
Amily Grey さんによる
Hi @shadyoskar ,
Try connecting an external monitor to the laptop's HDMI port and check if the display on it is OK.
Stupid thought but have you pressed the backlight On/Off key (F9 - not sure if it is F9+Fn or just F9) to see if the backlight goes on and off and the image appears/disappears?
jayeff さんによる
@amily I've been busy for the past week so i couldn't reply but yes, i have and it cracked a tiny bit. I was worried that it was this but i wasn't sure. I thought if it was the screen, it wouldn't even turn on for a second.
Oskar さんによる
@amily *I dropped it
Oskar さんによる
4件以上のコメントを表示
