What should I do if my WiFi is not connecting to the camera?
I can’t get my WiFi to connect to the baby camera, what should I do?
Not Connected to Specific Wi-Fi Network
Make sure that your phone/device is connected to the Wi-Fi Network that is specific to your Wi-Fi Baby Camera (called “myBabyCam-xxxx”). The “xxxx” part of the Wi-Fi will be specific to every individual Wi-Fi Baby Camera and is located on the label on the back of the Wi-Fi Baby Camera as well as on the back of the quick installation guide.
Go to your phone/device’s settings, select Wi-Fi and check to see if your Wi-Fi is on. If not, switch the Wi-Fi on.
First, check that the Wi-Fi Baby Camera is plugged into an electrical outlet. If it is, press the power button located on the front, upper right side of the Wi-Fi Baby Camera.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 248
student question
mayer さんによる
