メインコンテンツにスキップ
Charges fast and dies fast
Hey I have a iPod touch 6th gen come in for repair
anyways, this is the third one that came in wasn’t charging or turning on… so I decided to change the battery and re solder a new one in. It’ll charge very quickly and drain fast as well. I’m not sure if it’s the batteries I am getting off eBay or if something hardware is at fault on the logic board causing this issue. Is this a U2 IC Failure? Any shops that have this same problem it would be great if you could chime in with a Solution. It also recognizes with the computer and charges at 0.72 volts
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
Try the battery that iFixit sells.
iPod touch (6th and 7th Gen) Battery
iFixit generally has decent quality batteries.
Replace a battery compatible with a 6th or 7th generation iPod touch model A1574 or A2178. Part #020-00425. Battery Model #A1641. 3.83 Volts (V).の画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
ipods generally have a terrible battery life,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Daniel Ringuette さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 2,576
