メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Which part do I need to change?
Hello guys. Last week i bought an iPhone from craigslist for pretty good price. However, it has one flaw. It looks like front microphone, speaker and light sensor are not working very well.
In videos recorded via back camera sound is ok, voice memo works great, i can call without problems, even videocall on messenger works great but when i try to use Siri or record video with front facing camera, the sound is just buzzing and weir noises. When i speak directly to the grille above display it is a little better but it still sounds like whispering in a blizzard …
Another problem is the top speaker, which is a lot quieter than the lower one. Also the sound quality is worse. And light sensor is also not working (which is strange because proximity sensor works just great).
I changed battery and lightning connector on this phone, so i tried to clean up the speaker but it still does not work. Everything is connected firmly and nothing seems to be damaged. So my question is which part do i need to change?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You’ll want to change then the FCAM/Sensor flex. It handles the ambient light sensor, proximity sensor, microphone, ear speaker and obviously the front camera. While you’re doing this, you should also clean out the grill which may be clogged with lint and dust.
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
Thank you. I will replace the part . Shame that i need to change front camera, i think that no OEM part can match the quality of apple˙s original camera :/.
さんによる
I wouldn't worry about he FCAM, it's a pretty generic design. Apple advances the tech on the rear camera, the FCAM has not changed in a while.
さんによる
コメントを追加
回答を追加する
popradskakava さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 57
