Why won't my roomba hold charge?
I have two roomba 360s. One won’t hold a charge for more then a minute and then it dies, the other aon’t charge at all it says “charging error 3” . How do i fix both of these problems ?
First, turn your Roomba upside down and clean the battery contacts on the base. Unplug the docking station and clean any dirt or debris off the contacts there too. If the contacts are rusty the rust will prevent the Roomba from charging properly. Get an emery board or fine nail file (I used the cardboard type as they are more flexible) and gently sand off any rust. This may get your Roomba charging again.
As this is an earlier model Roomba the battery maybe due for replacement. Even a rechargeable battery doesn’t last forever. Later model Roomba’s have software that won’t let them take non-original parts but yours might not have this issue.
このアンサーは役に立ちましたか?
I don’t dock mine, I plug it in. Now what?
このアンサーは役に立ちましたか?
Battery replacement.
This rumba is only a year old and it doesn't hold a charge, what a piece of junk
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 6,314
