メインコンテンツにスキップ
Repair information and troubleshooting for the 50, 55, or 60 inch UHD Samsung TVs with model number JU6800, released in 2016.
6回答 すべてを表示
Random Intermittent Backlight Issue on Samsung JU6800 LED TV
For the last few months I’ve been having what I assume is a backlight issue where the bottom half will go darker than the top.
It is completely random, sometimes will just flick on and off now and again, sometimes it’ll stay one way or the other for a few days. See: https://youtu.be/imiNzNXKkFc
It is on all inputs and the OSD, I’ve tried leaving it unplugged for a few hours and fiddling with backlight related settings.
After a while of intermittently occurring, it seemed to have stuck for good. So I completely disassembled it to investigated the boards, connections and LED strips. Everything looked fine, and of course it decided to just start working perfectly again… for a while. After a few weeks of working perfectly it’s started happening again!
Any inkling on what could be the cause?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
I have exactly the same problem.. the bottom part of my TV JU6800 just died and never came back. Did any one find what needs to be replaced, please let me know.
さんによる
I fixed mine. I tossed it and got a new TV!
さんによる
コメントを追加
2件の回答
ベストアンサー
@jakeii
intermittent issues are the hardest to fix. From the sound of it I’d be replacing the power board. Usually if it is an LED strip it will take them all out. The power board supplies voltages to the different strips and may be having issues with the ones that are not lighting up. Again, this is difficult to troubleshoot since it is intermittent.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks for the answer!
さんによる
I have the same issue with a Samsung un55hu7250f except mine is the top half that goes dark from time to time!
さんによる
コメントを追加
I had about the same problems with my 6850 TV.
After another tip, I soldered the connectors of the LEDs with wire. And now it works again!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jake Lee Kennedy さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 48
今までの合計 5,655
