メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duoプロセッサ
This is a special case...
I did a hard drive replacement on this iMac about a month ago. Have not used it for about a month. Today when I try to boot it up it beeps like it has no or bad RAM. I tried new RAM sticks to no avail, still beeping like it has bad RAM.
While removing the screen to replace the HDD, the vertical sync cable came out damaged. I did my best to put it back in. Would a damaged vertical sync cable be causing this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Is there a pattern to the beeps? Did you address the hard drive thermal issue if you changed brands of hard drives?
What are the diagnostic LEDS telling you?
さんによる
コメントを追加
2件の回答
ベストアンサー
I actually just solved my problem. I looted a display from an identical iMac that had suffered a fall and broke it’s foot (ouch!) and plugged it into the problematic iMac and it booted just fine. It was indeed the cable after all. @my64pro @mayer thanks for stopping by!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
It could be possible that this is why it does not work,the computer maybe detects that the LCD is not connected due to the cable being damaged. I recommend replacing it and see if that fixes the problem.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
I don’t think the vertical sync cable itself is replaceable. I think I am going to have to replace the entire display which is not economically worth it.
さんによる
You can replace the cable to the display,they sell the cables online.
さんによる
Where are these cables sold and how do I replace them?
さんによる
Looking on google,the price of these are very cheap
https://www.google.com/search?q=vertical...
さんによる
@my64pro Thanks for the link, however I have solved my problem. Thanks for stopping by anyways!
さんによる
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 249
