メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
締切られた回答
iPhone SE is broke after charge in the car
Hi,
I used an adapter for charging iPhone SE in the car, but after 5 min the iPhone SE arrested forever also if I pushed “power” button. So, I decided to replace battery, but I noticed that problem is another. I noticed that also if I put the display of this iPhone SE to another iPhone SE, this display doesn’t work, so probably also display is broke. I tried to put also motherboard of 64 GB in the iPhone that born with 32 GB, I removed motherboard of 32 GB and I put the motherboard of 64 GB, but also motherboard doesn’t work. I’ve worry, because in the motherboard of 64 GB I’ve many importants data. Someone that is really expert can tell me what happened and if is possible recover my data?
Thank you in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Data is important !
I would suggest that you get it to a repairer before it is corrupted.
The fact that the device has stopped working after using a car charger is almost a guarantee that the Tristar has failed and needs to be replaced.
You will need to look for someone that is reputable and does micro soldering in your area.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 40
