メインコンテンツにスキップ
Model zd8000, 17" Widescreen display, 2.8-3.6 GHz Intel Pentium 4 processor
8回答 すべてを表示
repairing pwer adapter on motherboard
following your instuctions to remove bottom plastic cover, got to removing the dvd player  where you say push pin in hole to open dvd player, the player opens, but the rest of the player will not budge from the hole no matter how hard I pull, help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Is your DVD player bent in any way, shape or form? If not, try doing the pinhole release one more time but push as hard as you can into the pinhole. That way if for some reason the release button is stuck it will become unstuck. Just my two cents.
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
did the pin hole thing, and slid the dvd player out but the rest of the dvd player assembly wont move from the slot
さんによる
need someone to tell me how to remove the complete dvd player assembly from the laptop hole
さんによる
I understand, but is the DVD player bent? Have you tried the thing I suggested above?
さんによる
no player not bent just wont budge from slot, are there any more screws that need to be released
さんによる
Thats very odd then, there are no other screws that need to be released or button to be pressed. I am skunked on this one.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Jack Carruthers さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 104
