メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
428回答 すべてを表示
My Xbox One S doesn't turn on, only light for 5 seconds and beep sound
I bought an old Xbox One S from a Flea Market, i paid that only 60 bucks. The merchant told me i will pay without the shop warranty, i just accepted the challenge. I literally tried the console but the Xbox One S gave me just the Blank Light, the beep sound and than, after few seconds it turned of by itself.
I tried everything i found on internet:
-I cleaned up every single spot on and inside the console.
-I changed the Thermal Past with M2.
-I checked up if there was some burned parts or some bad capacitors.
-I tried to do some things, trying to hold on the Eject and Power Button for 5-10-20 seconds, nothing happened.
-I tried the Hard Drive on my PC, and it works.
-I tried another 500gb hard drive with Xbox One S drivers installed but same result.
-I tried to ask to the Xbox One Live Support, they just asked me if my console had warranty and they told me without the Warranty i need to buy a new console.
I refuse to think there is not a solution, i repaired my old Xbox One and i bring back from brick of death to life, i know there is a solution.
I made a video of that problem:
https://www.youtube.com/watch?v=VKP3TplC...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Try a new power supply, there might be a problem with your existing power supply. I found this website saying that the power supply could be the culprit.
https://support.xbox.com/en-US/xbox-one/...
Xbox One Sの電源ブロック交換
Xbox One S Power Supply
Xbox One S Power Supplyの画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thank you very much for the answer. I opened up the power supply and i saw this. I can fix the coil, it seems like it has some signs of burning.
https://i.imgur.com/SC8ybdY.jpg
さんによる
@killercereale If you are confident you can do so I think that is where the problem lies. If fixing that coil doesn't help you are better off getting a new PSU.
さんによる
コメントを追加
回答を追加する
Cereal Killer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 2,767
