change vita slim motherboard with a different region model, possible?
i want to change my american ps vita slim with a japanese vita slim motherboard. Is it possible ? will all the buttons work properly ?
Hi!
Yes, you can use a motherboard from a different region in your Vita. Everything should be the same.
このアンサーは役に立ちましたか?
Thanks a lot for your information. I have one more query. As the button settings are a bit different in usa than japan("X" to select vs "O" to select), will this be any problem regarding the mother board change ? or is there any specific hardware design that might prevent me from changing the mother board ?
Thank you
Hi!
The boards are identical on a hardware-level. When you set your console's language to Japanese, it will change the button mapping on its own, but as long as you keep the language to English it's alright.
I'm not sure, however, why you need a Japanese motherboard specifically: the PS Vita is *not* region locked, you can play jap games on a North American console.
過去 24時間: 1
過去 7 日: 6
過去 30 日: 18
今までの合計 447
