メインコンテンツにスキップ
CDMA iPad 2モデルの第二世代は16、32、64GBのオプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1397です。修理は細かい作業が含まれ、熱で温めてこじ開ける作業が必須です。
52回答 すべてを表示
iPad Reboots After ~5 minutes Following Digitizer Replacement
I recently repaired my first iPad digitizer. The part I ordered was said to be OEM grade. Following the repair the device seemed to work fine. After around 5-10 minutes of use it would shut off and reboot. Tried hard reset, restore, and even some random work arounds that were recommend to me. After restoring I was able to use the device for several minutes and didn’t have any issue. I let it sit for several hours and never had it reset. Returned the device to its owner and they said it started to do the same thing. My question is what could cause this and what I need to do to prevent it in the future.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
Did you remember to put the screw back in for the battery connector?
さんによる
Do believe I did, but I remember having some issues. Think that the solution is that simple?
さんによる
There may also be a bit of glass between the board and battery causing a bad connection. Sitting motionless wouldn’t cause a problem, but moving the device around could cause it to pull away from that connection slightly
さんによる
I’ll have to open it up again and take a look. Thanks guys.
さんによる
I only asked because I have forgotten that screw once or twice. haha.
さんによる
コメントを追加
1 件の回答
ベストアンサー
You’ll want to get that iPad back and open it up. As others have suggested, make sure the battery connector is screwed on tight. While you’re at it, you should also test the condition of the battery with 3uTools or coconutBattery.
I would also try another digitizer if you have one on hand to see if that makes any difference.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Austin Ledet さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 11
今までの合計 131
