メインコンテンツにスキップ
The Bose 3-2-1 Home Entertainment System is a series of DVD-based home media systems in the Bose 2.1 home theater line. The Bose 3-2-1 Home Entertainment System was sold between 2001 and 2006 and was available in black and graphite colors.
91回答 すべてを表示
Acoustimass module lightly hisses but has no sound output at all
I’ve had a 3-2-1 system for some time but it has been in storage (A closet) for a couple years. When fully connected the media center powers on fine, the acoustimass module only hisses (it does get louder as the volume is turned up on the media center) and nothing whatsoever is output to the speakers themselves.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi @thenewelite ,
What signal sources did you try, radio, DVD, external etc. Did you try all of them to hear if any worked?
さんによる
Hi @jayeff ,
I used CD, aux input (from two different sources) and FM radio. I have a spare set of speakers as well as cables of which I tried both, so I'm assuming the problem lies somewhere within the acoustimass module. All of the above ended with the same hissing and no output to speakers
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi @thenewelite
The problem may not be in the acoustimass, it could be in the media console or even the cable connecting the two.
Even though the other speakers work when connected to the console this doesn’t mean that the audio signals are being sent to or are being received by the acoustimass, if you get my drift.
Hearing a hissing sound at least proves that the power/amplifier section of the acoustimass may be OK.
On p.37 in the Troubleshooting guide (see link below) it details how to make a base module (acoustimass?) test wiring cable so that it can be tested to see if it is OK or not. At least by doing this you can prove where the problem is located.
Here’s a link to the troubleshooting guide for the system.
To download the file, when the sentence below the Document preview box changes from This file is downloadable free, of charge: ...processing... to This file is downloadable free of charge: Download, click on Download. Be patient it takes a little while to find the file.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I'll try that and see where it gets, thanks.
さんによる
Brant, did you find a solution to your issue?
さんによる
コメントを追加
回答を追加する
Brant A. さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 9
今までの合計 861
