Where can I buy the awm 20798 80c 60v e357723 replacement ribbon?
I need to know where i can buy this ribbon cable from
この質問は役に立ちましたか?
この質問は役に立ちましたか?
What I always say is if it isn’t on eBay it probably doesn’t exist! If you can’t find the precise part number sarch for HP Stream 11-d020nr spares and you may find a vendor you could message to see if he could supply it. Alternatively, search for another laptop of the same model offered as “spares or repair” but with a different fault, from which you could cannibalise the required part.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 6
今までの合計 259
1件のコメント
Hi @tanaya234 ,
What does the cable do?
It might be easier to find if its' function is known e.g. display cable, keyboard cable etc?
jayeff さんによる
