メインコンテンツにスキップ
The HP G62 is a laptop series produced by HP. G62 laptops are identifiable by the model number G62-XXX-XX, and endings vary depending on options and seller.
33回答 すべてを表示
Blinking caps lock solid red wifi light.
It blinks every 4 seconds or so. Solid red WIFI light. No beeps. If I leave it on for a while or really any time it gets hot it boots like normal and has no problems until it cools down. Why is this happening? Is it time for a new laptop? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
- Start by doing a hard reboot, remove the battery and unplug the AC adapter then press and hold the power button for 20 seconds then try booting it up again.
- If this will not work, do test the AC adapter if it's working properly. Remove the battery and power the laptop with just the AC adapter connected and see if it will boot up or not. do also try a different AC adapter that has the same voltage and see if it will work or not.
- Proceed with reseating the RAM's if trying a different AC adapter will not work, remove them all for couple of seconds then put them back in making sure everything is seated properly.
- If it will still not work, connect an external monitor and see if you'll get any display from it. If there's a display on the external monitor that could mean that the problem is the built in display.
- But if there's still no display on the external monitor that means the problem lies in the motherboard.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ive already tried that. Im just trying to figure out why it only boots when its hot
さんによる
コメントを追加
回答を追加する
Ethan Leroux さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 2,842
