メインコンテンツにスキップ
モデル番号A1286、発売日 2011年2月/2.0, 2.2もしくは2.3 GHzクアッドコアIntel Core i7プロセッサ
586回答 すべてを表示
Updating from MacOS 10.7.5 on early 2011 MacBook Pro
I recently replaced a dead battery for my 2011 MacBook pro, I am still running the out-of-box OS Lion 10.7.5. Mojave is not supported but I am missing out on an array of other operating systems. Is there a way to update to say Sierra (or really anything other than Lion because this thing is REALLY starting to show it’s age. The App Store doesn’t appear to support any of the older non-Mojave OS’s and I am at a loss.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
High Sierra is the most modern version I’ve been able to tolerate right now. The problem with Mojave is APFS isn’t optional (even on a spinning drive) so you end up using a filesystem that’s not designed for the drive it’s being forced on. If you still find a way to opt out, Apple won’t provide system updates. You either become an APFS user against your will or you won’t get updates.
Stick to High Sierra for the time being. It’s not much less feature rich then Mojave anyway, so you aren’t losing much. I got my installer from the dosdude1 patcher. Mojave sits on my drive uninstalled since I grabbed it thinking I may do it sooner then I thought I would initially. I don’t think so - at least until Apple realizes that APFS is not for spinning drives and these should default to MacOS Extended (Journaled) AND provide a easy APFS opt-out for those of us who do not want it.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You simply search High Sierra download online. There should be a free download from apple’s website. I hope this helps.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If you can borrow a friend’s Mac that supports the App Store you can create a bootable USB that should work with your Mac using the guide below.
https://support.apple.com/en-us/HT201372
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josh Maupin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 922
