Recall - recycle or repair?
The Big Blue has been recalled - out of 164,000 sold, “12 reports of the speakers overheating and catching fire, resulting in five reports of property damage totaling about $2,000 “
https://www.cpsc.gov/Recalls/2018/brooks...
Very disappointing, I really like our Big Blue! Does anyone have more information?
この質問は役に立ちましたか?
3 件のコメント
Has anyone tried any of the aforementioned fixes regarding replacing the battery with similar batteries? Or rewiring it to be powered exclusively off the power cord? I’d be fine with that as an alternative and just drop the battery power all together if that’s the safest option that still allows me to keep the speaker (I really like have it for Chromecast out on the deck and nobody else seems to make the same product functionally).
Jonathan Alstad さんによる
You can just remove the battery no rewire required I just removed the battery and use the power cable works great.
XMTS LABREAKERS さんによる
Solution for the pack: get a new pack that uses a protected cell like Samsung 30Q. These will internally disconnect the cell if the cell overheats.
My original pack lost capacity, so I replaced it with 7000 mah (versus 4400 mah) pack. The difference is using Samsung 35 E cells. Charger uses a near constant low current as opposed to starting with higher current and ramping down. I monitored a charge and the charging voltage reached a peak near 12. 8 volts, leaving pack at 12.6 volts, which is OK. Pack wasn't even warm to touch.
I got the pack via ebay. The pins in the plug were reversed, so I had to swap them.
Potential issues: a charger that overcharges pack. An pack with a weak cell that would overcharge that cell with pack at 12.6 volts. Something that could short circuit the pack.
Laying the charger on it's side when charging would reduce risk of fire, since the pack is at the bottom. Taking off the bottom cover to expose the pack would allow the temperature of pack to be monitored.
rcgldr さんによる
