メインコンテンツにスキップ
The Dell Inspiron 17-3721, manufactured by Dell, is a 17-inch laptop that is powered by an Intel Pentium and 4GB of RAM.
3回答 すべてを表示
I need a good DC jack replacement guide.
Hello, I recently moved my hard drive over from one Dell Inspiron 17-3721 to another. The first had motherboard failure but this one now has an issue with the DC power jack. Does anyone know of a good repair guide and a good place to get the part?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @mannermauler ,
Here’s a link to the service manual for your laptop, taken from this webpage
Scroll to p.73 to view the necessary pre-requisite steps and then the procedure to remove the power adapter port. (Their name for the DC-In jack)
Replacements are available online, just search for Dell Inspiron 17-3721 power adapter port part to get results. Here’s a link to just one supplier of the part. It is shown only to give you an idea of the cost of the part and also the various Dell models that the part is compatible with.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
To start (if both laptops are identical) take a look at this video:
https://www.youtube.com/watch?v=bhyi4_i7.... It seems that the jack is a cable not soldered.
if they are not identical anyway the video will give you an idea of how to get to the jack.
if it is a cable it has a sticker with the model number.
if it is soldered you best shot is take it to a repair store.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MannerMauler さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 15
今までの合計 204
