メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Toshiba テレビの修理ガイドとサポート情報です。
Toshiba 50L1350UC Tv black screen , sound ok
Screen turns on normally for few seconds then goes black Flashlight shows words images on black screen Audio is normal What should I do next?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
my model number is 49L621U. I jumped the gun and changed out the Video/Main board. I will try a reset and go from there.
さんによる
Reflow t con board worked for me . Took a couple goes for fix to stick though. 400-450 degrees
さんによる
@jerrycienfield you did the flashlight test before you disassembled your Hitachi and could see the outlines etc. and the backing of the main board fixed that too? Or was yours a completely black screen with no outlines etc.?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
pharmoron  since you are seeing things when you are using a flashlight, it is clear that your backlight is out. This could be an issue related to the power board not providing power to the LED’s; the mainboard not supplying the signal to turn the backlight on (unlikely) or a failed backlight array. Test the LED connector on the power board with a voltmeter (DC voltage) and let us know what values you get.
Toshiba is another black helicopter company that is absolutely paranoid about DIY’ers and of no help at all. We will rely on you to provide images of your boards as well as the voltages etc. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
pharmoron さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 32
今までの合計 3,796
