メインコンテンツにスキップ
2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
Why is this MagSafe2 cable turning yellow?
A teacher from my high school came to me with her MagSafe2 charger for her MacBook Air and asked me why it is yellowing. Is this dangerous to the point where I should give her a new one or is it just grime/dirt. If it is grime/dirt how would I go about cleaning it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
I’d tell her to replace it because there is clearly several nicks in the insulation/cover on that wire… perhaps the wiring underneath is damaged from being coiled up or cut or whatever..
other than that the yellowing could be aging from sunlight exposure ie that’s the part that sits on the desktop and sees most light (the rest dangles down to power point)
or it’s heat from electric supply that is degrading the colour of the white insulation.
Either way it is better to be safe than sorry
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
@pollytintop Thanks for the information! I will advise this particular teacher to ask for a new cable.
さんによる
@pollytintop - Dirty hands ;-]
さんによる
True @danj ...
さんによる
This happened to a few of my Mac cables. I’m pretty sure they are from overheating. Apple recommended to not use your computer while it’s charging and that should fix the issue on your new cable.
さんによる
コメントを追加
I’m not sure about sunlight causing these. I never used charger outdoor. I have a 13” and 15” mbp, magsafe-3 oem and 2 3rd party (lot cheaper-could be refurb? Got one from WM for $15). So far, only the OEM parts are the ones that are browning. I will go with apple explanation and I use the OEM’s as spares. One of the 3rd party seller quit working after about 8 months. It’s under warranty, so they replaced it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 24
今までの合計 23,073
