メインコンテンツにスキップ
A 16 GB Android tablet with a 7.9 inch display manufactured in 2014 by Xiaomi.
29回答 すべてを表示
My pad is cracked, has black dots and is hung...can it be repaired?
I dropped my pad now its screen is cracked, it has black spots and vertical colourful lines, its hung, and also won’t respond if I click the home button (home and back are being displayed)….will it work again?? can it be repaired?? please help me
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Yes, you can fix this. However you will need to buy a new screen and digitizer assembly.You will also need to buy new 4 MM adhesive which I have linked to also.
https://www.parts4repair.com/complete-sc...
Tesa 61395 Tape
Here’s a tutorial on how to do said replacement/repair. You will need to heat up the bezels of the screen so that the old adhesive melts and then you can use an opening pick or something of the like to peel the existing screen off your tablet.
https://www.youtube.com/watch?v=ELQj_dwQ...
Tesa 61395 Tapeの画像
製品
Tesa 61395 Tape
$5.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kassidy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 60
