メインコンテンツにスキップ
2018年3月に発売されたSamsungのGalaxy S9の修理ガイド。
137回答 すべてを表示
No input or output on incoming calls
I have a Samsung Galaxy s9 and whenever I receive incoming calls, I can’t hear anything the person calling says like there is just no sound. I also confirmed that the person calling can’t hear anything I saw as well. When I call the person back everything is fine and normal so the issue is only when I receive calls.
Any help would be great.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Have you tried turning the phone on in Safe Mode? If you open your phone up in Safe Mode and you are able to receive calls, then it is most likely a software problem.
To open your phone in Safe Mode:
  1. Turn the device off.
  2. Press and hold the Power key past the model name screen appearing on the screen.
  3. Release the Power key when "SAMSUNG" appears on the screen.
  4. Press and hold the Volume Down key immediately after releasing the power key.
  5. Continue to hold the Volume Down key until the device finishes restarting.
  6. Release the Volume Down key when "Safe Mode" appears in the bottom left corner of the screen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gary さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 58
