メインコンテンツにスキップ
2018年9月21日発売。モデル番号A1921, A2103, A2104、GSM もしくはCDMA / eSIM もしくはナノSIM /64, 256,もしくは512 GB/ シルバー、ゴールド、スペースグレイ(正しい発音は"iPhone 10 S Max")
375回答 すべてを表示
repairing back glass iPhone xs max
Hwy, do you guys know how to fix the back glass of iPhone XS Max?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 13
1件のコメント
Hoy iphone está bloqueando el Face ID solo por cambiar la carcasa por que será??
さんによる
コメントを追加
11件の回答
最も参考になった回答
My understanding is that if you heat up the back with a heat gun or blow dryer you can peel the glass off as it’s held on with adhesive. If you broke the back glass you really have nothing to lose with getting it off, you can hack away at it until it’s off with an opening pick and/or a Jimmy. Just don’t use excessive force in a way that would damage other components of your phone. Make sure you have your replacement back glass on hand before doing this, though!
HOWEVER…
There is no such replacement back glass existing at the moment that would work for this phone that I am aware of at the time of this post. You may have better luck finding that part.
iFixit Opening Picks (Set of 6)の画像
製品
Jimmyの画像
製品
Jimmy
$7.95
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
This repair has been made intentionally difficult. You will either need to heat up the glue to soften it and hack away at the glass, or freeze the back and chip it off. This can damage your phone, so take everything out of the housing first. You will then need to clean the glue off the frame, and then re-glue it back on (the exact glue I am not sure of). However! The glass to replace it with does not exist yet, and when it does, it will either be blank or be breaching copyright laws (as it has the apple logo on it). It cannot be done at this stage, and (I can’t believe I am suggesting this) either live with the cracks, use a skin or a case to protect it or if you really want it fixed, give it to apple.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I have just done a back glass replacement. No big issues, have to have a focused heat gun to heat the adhesive. Several videos of this being done on youtube. Ordered rear glass from DHgate
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Can you provide a link to the seller? Thanks.
さんによる
Can you tell us which back cover you got from DHgate? There are a number of them and it is hard to assess which ones are appropriate for an iPhone xs white
さんによる
コメントを追加
I have some small cracks in the rear glass on one corner. I don’t remember dropping it, but the cracks start at one corner, so it must have gotten dropped at some time or another. The phone works fine, so my comment is why bother to fix it at all? Who cares? It certainly isn’t worth $599.00 to get it fixed.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Replacing the whole housing is the easiest option, but if you want to replace the glass, heating the back is possible, and some people say cooling the phone with liquid nitrogen is easier, although both are intentionally extremely hard.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The issue that comes with replacing the back panel, is that it’s glued onto the internal housing. The actual internals are apart of the back panel, and not the front.
Apple is currently 'repairing’ devices with cracked/shattered/damaged back glass panels by replacing the entire internals.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Just replaced the whole housing it’s much easier and purchase the “naked frame” because only OEM cables seem to work properly with this phone
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
画像の内容を見る:
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Laser machine. This machine can efficient separating iPhone xs max back glass. Search video guide from YouTube. And I know REWA have pulished a nice tutorial on their official channel.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How do I get adhesive off the back of the phone without a adhesive gun or a Heese of plate
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How do I get the Hee-seop off the back of my iPhone without using a Heese of girl or a hair dryer
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
You really can’t you damage your phone trying to pry it off you can buy a small heat gun from home Depot for about 30 bucks better then paying 300+ for someone to replace it for you
さんによる
コメントを追加
回答を追加する
Ahad shabbir さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 23
今までの合計 76,091
