Hi,
I had this problem with a D85 Botvac. Contacted Neato support and they first informed me that my unit was (literally) 1 month out of warranty (so no surprise there) then proceeded to give me some crazy minimum price for them to fix this. As I had previously opened this baby up due to a broken drive belt for the side brush, which can be replaced with any suitable sized O-Ring, I decided to take a look.
After poking around and measuring voltage and continuity here-and-there, I discovered that the problem was located with the actual on/off master-switch (or battery isolation switch) itself which had an intermittent fault. Don’t get me wrong, a dying battery WILL give you this fault also, but if you replace that and still have no luck then you need to either clean or replace that switch (cost is about €0,50 in any decent electronics store).
I managed to initially get mine working by shooting some compressed air into the switch then a little contact cleaner spray (the type that evaporates - wouldn’t recommend WD40 or anything similar as the switch is pretty exposed to dust flying around inside). That lasted about a couple of months until the next incident so I just replaced the switch - three easy desolder/solder joints and as good as new - been running 100% since then.
Hope this helps anyone out there with this annoying problem.
