メインコンテンツにスキップ
Microsoft Corporationによって製造されたXboxワイヤレスコントローラー7MN-0001は、PCでも使用できるXboxゲームコンソールに最もよく使用されるコントローラーです。
127回答 すべてを表示
How would I fix a loosened micro usb port on an xbox one controller?
so when I plug a micro usb cable into my xbox one controller, the port on the controller would wiggle when touched and would barely power on the controller. If the controller were moved slightly, the cable connected to the controller would turn off the controller until it’s placed on a flat surface.
I think I caused the problem by accidentally dropping my controller while my cable was plugged in.
with that being said, is there any solution (besides buying a new controller) that can help?
Thank you in advance for the responses
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Use long rubber band to somehow make an X shape in middle of controller. Might need to carefully adjust the rubber band until it loops around the neck of cable
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi @dvorak ,
If the USB port is only loose and the pins aren’t damaged etc, then most probably all that is required is that the USB connector be resoldered back onto the motherboard.
Here’s a link to the ifixit Xbox One ワイヤレスコントローラの下部基板の交換 guide.
If you click on the 1st image in the guide you see the USB port at the top of the picture.
Once you have access to the motherboard it can be resoldered back on.
You’ll need SMD (surface mount device) soldering skills and tools to effect the repair.
If this seems too daunting, take the motherboard (handle gently) to a reputable professional electronics or mobile phone repair service and ask them to do it for you. As you have already dis-assembled the controller (and will re-assemble it yourself ) this should minimize the cost of the repair. Also SMD soldering is not that easy if you’ve never done it before. You may cause more damage than what you had it the first place.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Josh さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 33
過去 30 日: 124
今までの合計 22,740
