Mac Pro (Late 2013) Won't Boot but Appears in Disk Utility
I bought a Mac Pro (late 2013) [macpro6,1] from a friend and installed a new flash SSD. To help cut to the chase with formatting, I used a bootable USB to load Mac OSX Mojave and can confirm through terminal info that the new ssd, named “NewSSD” has an APPL_HFS partition type, Journaled HFS+, OS can be installed, and the device is internal.
I can select NewSSD as the startup disk and have tried to boot to it, but can’t for the life of me get it to function and start the operating system.
I have tried reinstalling a few times and the same thing occurs.
HOWEVER, I tried using 2 other bootable USB drives and then the internal disk does not appear in disk utility in recovery, so for some reason it seems to only be recognizing the disk when I have my original boot drive plugged into the USB.
So to recap, I can see the NewSSD in disk utility in recovery, I’ve run first aid on the drive no problem, but then it doesn’t boot the operating system.
Any thoughts? @danj ?
4 件のコメント
@mayer Dr. House of Macs might be able to help here...
[deleted] さんによる
Who's SSD did you use and its size?
Dan さんによる
I am using a Samsung Evo 970 with an adapter, I got this drive and adapter because others with the same model have had success getting the drive installed and running. I can see the drive after I boot holding option+command+R. I erased the drive and formatted the drive with Mac OS Extended (Journaled) with GUID. I then tried to install Mac OS X Mojave and with 1 minute remaining the computer resets and then restarts to the question mark file. I shut down and started again with c+o+r and it now shows 6.71 GB used but still can't get it to startup to the disk or operating system @danj
Justin さんによる
Might be something to do with the formatting of the SSD. I always do it Journaled and not HFS before installing OS because for some reason I get a flashing folder icon after installing the MAC OS high Sierra or newer.
Ben さんによる
