メインコンテンツにスキップ
Repair information for the Asus Transformer Book T100TA. Released ~2013. Model number: T100TA .
76回答 すべてを表示
Asus T100TA White screen upon startup
I have an Asus T100TA. Everything was working fine and then all of a sudden I have a white screen. I have tried to do a reset by holding down the power button for 10 sec. but it wouldn’t do anything. It has now been unplugged for 3 days (so I thought the battery would die) but when I hold down the power button, I keep getting the white screen. Tried to find video’s on YouTube for a fix but can’t find anything specific to this laptop.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Connect an external monitor to the laptop and check if its' display is OK when the laptop is turned on.
Assuming that you may have Win 10 installed, try starting the laptop in safe mode (see options 4,5,or 6) and see if the screen works OK then.
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
I am not able to connect an external monitor as the Asus does not have a port for that.
さんによる
Hi,
According to the User manual taken from this webpage the Asus T100TA has a micro HDMI port (see p.14 item #8 for location)
さんによる
Sorry, it does have the HDMI port but the monitor that I have does not not have an HDMI connector so unfortunately, that does not help me unless I go out and spend money on another monitor.
さんによる
Hi ,
OK how about your TV if you have one, does that have HDMI inputs? You'll probably need a micro to standard HDMI cable to connect it tothe TV
Still try the safe mode options in case it is a driver problem and hopefully not a display or motherboard problem
さんによる
Yes, I can connect it to the TV! I will try that and start it in safe mode. Thanks!
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Mariana Siry さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 710
