メインコンテンツにスキップ
Should I replace the Magsafe Adapter?
About a year ago a friend dropped my Macbook on its upper left corner, denting it. Since then, the charging has been quite erratic, and it's getting worse.
Often, I connect the 85w adapter ten or twelve times to start the computer charging. Sometimes the LED turns green, sometimes not, and the battery doesn't charge either way.
Until recently, an orange LED meant success: the computer was charging. Now, it's no guarantee, and sometimes it will charge with no LED at all.
Sometimes (not always) the connection between the charger and magsafe gets quite hot.
I have tried to clean the Magsafe from the outside, which may have improved it a little.
I am looking for a solution that doesn't involve a new computer as the budget is quite tight right now. I have the impression that changing a magsafe is a difficult job.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
+ well written question
さんによる
Hello Mayer and Remacberlin,
I ordered the part, and when I was forced into action by the machine refusing to take a charge any more, I replaced the i/o board with a friend's help (he claims I was essential, I'm not so sure!) It was a lot of fun to go "under the hood" and it worked.
So thanks again for your help! Cheers.
さんによる
コメントを追加
2件の回答
ベストアンサー
Replacing the left I/O board seems to be the reasonable course of action at this point. Here's how to do it: MacBook Pro 15" Core Duo Model A1150 Left I/O Board Replacement
Here's the part to do it: MacBook Pro 15" (Model A1150) Left I/O Board
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Ouh, mayer beat me to the answer. +
さんによる
Thank you, Mayer! I'll try this.
さんによる
コメントを追加
If you feel confident stripping and reassembling your laptop, take it apart, try to undent the bottom case and maybe change the left IO board. At a last resort you can change the power adapter as well, but judging from your story i think the problem is a bad fit of the connector and you'll have to tackle the problem from its source.
Repair guide here.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
+ no flies on your answer either.
さんによる
it's very encouraging that two people think it's the same issue! I feel anything but confident about reassembling, but I will try to find a tech-astute friend as backup.
さんによる
コメントを追加
回答を追加する
Tricia さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 3
今までの合計 1,708
