メインコンテンツにスキップ
The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
19回答 すべてを表示
Air intake on base totally clogged how to clean
On the base of the fan the intake totally clogged with dirt how do I take it apart to clean
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
1件のコメント
It's got loads of dust coming out the holes I have COPD and wheelchair bound so I haven't got a clue I'm on my own?
さんによる
コメントを追加
4件の回答
最も参考になった回答
https://www.instructables.com/id/Dyson-A...
Please see the above article I posted on how to take apart and clean the internals of a Dyson tower fan.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Perfect cleaning manual!
さんによる
Thanks!
If only I had remembered to take a picture before cleaning.. It was so full of dirt. as though Dyson had stuck one of their vacuum cleaners to a ring to come up with a fan.
さんによる
Very good! I just wish that I’d looked online first it would have saved me so much time! I’m glad you put in that bit about the ring not being made to dissemble…….I thought it was me….I had spent ages trying to find release points but to no avail. Thank you rakone that was spot on.
さんによる
Thanks! Glad my answer helped.
Do upvote it as i'm new here :)
I'll try to transfer over that instructables to ifixit soon.
さんによる
コメントを追加
Vaccum with a brush attachment..obviously use a powerful vacuum..this upkeep should be done biweekly
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You can remove the cover and the filter of the tower fan with the help of this video here. You can then clean the cover and/or change the filter.
https://www.youtube.com/watch?v=UXwqFhfG...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No Aaron, read: AM07, NOT the Pure Cool!
さんによる
コメントを追加
One way is to spray water on the inlet holes and clean the accumulated solid dust with a toothbrush.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Whojuno さん、ありがとうございました!
統計データ:
過去 24時間: 13
過去 7 日: 91
過去 30 日: 402
今までの合計 55,211
