メインコンテンツにスキップ
Second generation of the Ford Focus.
95回答 すべてを表示
Having trouble with a 2007 Ford Focus, what do I do?
Having trouble with a 2007 Ford Focus, getting spark fuel, everything just will not turn over
bumped the coil will not start.
the alarm light keeps flashing ran a tester wire is enabling through the alarm system everything is working but it will not turn over and start but it turns over when I bump the solenoid with the battery but will not start
what could it be tried the ignition switch key and key reader
I tried the ignition switch relay those were good and checked all fuses everything is all good but I think it has to do with the alarm on the car itself
what do I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I know this may seem like a stupid question, but did you check the starter itself? Also there are usually fuses and relays underneath the hood, did you also check those?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Harvie Oconnor さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 74
