メインコンテンツにスキップ
7つの異なるジェネレーションから成るiPod Nanoモデル
1006回答 すべてを表示
I forgot the pass word of my iPod classic model. no.A1236?
my brothers girl friend gave him dis ipod and then gave it to me i locked it and my brother doesnt know the password. We tryed calling her but she doesnt hav a phone right now?? how can i reset my password??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
1件のコメント
this is very help \ful
さんによる
コメントを追加
2件の回答
ベストアンサー
Here is my answer as previously at Why cant I do a hard reset to the screen to unlock
"If you forgot the combination, the only way to unlock the iPod and enter a new one is to reset it to factory settings. This means that you will lose all your data on the iPod. To restore the iPod to factory settings you have to connect the iPod to its primary computer and select “Restore” from iTunes > Summary tab.
THIS WILL MAINTAIN YOUR DATA
Now I think if you are using windows you can also try to
1.Plug the iPod in computer.
2.Go to "My Computer" And click the apporiate drive your your iPod.
3.Change folder option to "View all hidden files and folders"
4.Go to ipod_control
5.Then to Device
6.You should see a file there named "_locked"
7.Open that up with a text editor (Notepad) and the passcode should be right in there.
or of course you could just rename the file to _unlocked
Close your text editor and eject iPod from computer
Good Luck
このアンサーは役に立ちましたか?
スコア 9
4 件のコメント:
renaming the file to _unlocked works better than trying to check for the passcode within the file! :-)
さんによる
Thank you, you just saved my life
さんによる
I have a question I have the A model 1238 it has the lock symbol on the screen how would I reset it without a computer
さんによる
What if I cannot connect to iTunes, or if I don't have a cable? I'm not interested in saving all the songs, I'm just interested in getting my iPod back, even if it is erased. Is there any way to reset it using the buttons and click wheel? Like a manual reset on the device itself instead of through another device? By the way I have model A1136, EMC No. 2065, 30GB, released in 2005 (I have it in white (Well, the back is silver))
さんによる
コメントを追加
If you encrypt an iPod backup on iTunes and then forget your password, you will not be able to restore from backup and your data will be unrecoverable. If you forget the password, you can continue to back up and use the device, however you will not be able to restore the encrypted backup to any device without the password. You do not need to enter the password for your backup each time you back up or sync. If you cannot remember the password and want to start again, you can use a SmartKey to unlock iTunes backup password at first.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
さんによる
コメントを追加
回答を追加する
tanya さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 27
過去 30 日: 85
今までの合計 19,852
