Mirror problem with light telling someone is passing
The light that tells you someone is passing you is not working?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @harryii ,
Is the Blind Spot Monitor function light coming on in the dashboard instrument cluster, when you first turn on the ignition key?
Here’s a close up of what it looks like (picture of a car in an exterior car mirror)
If this light is not showing when you first turn on the ignition you need to activate the Blind Spot Monitor system.
(click on images to enlarge for better viewing)
このアンサーは役に立ちましたか?
Thank you for your help.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 415
