メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad Air Wi-Fi +セルラーモデル、モデル番号はA1475でスペースグレイかシルバーのカラーが選べ、容量は16/32/64/128 GBがあります。
Replacement of cracked ipad screen
My ipad screen cracked like in the picture. Ipad display can be seen and the touch responses well.
I want to fix it myself and am planning to buy the screen. But there’s a lot of choices; cheap or expensive ones.
Can i buy a screen like this? https://www.lazada.com.my/products/white...
Update (09/28/2018)
Can you give me an example of what kind of parts should I buy? I’m also confused on what to buy because I found out there’s a few variations of screens; lcd/digitizer/touchscreen/etc.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Sure you can do this yourself! You have to have a steady hand and be patient in your work otherwise you will create problems for yourself. I would recommend you read through this guide first to see if you are comfortable with the steps and tools required.
As for the parts, I can’t speak for the supplier you linked. However my one piece of advice here is don’t go for the lowest cost parts, ultimately, you always get what you pay for. Look for a reputable vendor that offers a real warranty and return policy. then if they have a premium or OEM version of the part, go for that if your budget permits.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Everything is listed out in the guide.
さんによる
コメントを追加
回答を追加する
tikus belon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 387
