Sony error E:91:01) how fix this error?
How fix this E:91:01 Error Sony HX90V?
Thank´s for all.
Sincerely.
Gil
この質問は役に立ちましたか?
Thank´s for all.
Sincerely.
Gil
この質問は役に立ちましたか?
After reading up on some forums about this error code, I came to the conclusion that a factory reset is necescery.
You can perform a factory reset by going to the main menu -> Settings -> Initialise -> Factory Reset.
Report back if it works or not!
このアンサーは役に立ちましたか?
The Above Answer Worked!
Many Thanks ! :)
No it did not clear this error code.
No, it did not work. :(
過去 24時間: 2
過去 7 日: 14
過去 30 日: 50
今までの合計 8,311
