メインコンテンツにスキップ
A general-purpose audio device that transmits low audio frequencies to your ears.
22回答 すべてを表示
What is this burned piece called
Punched my subwoofer cuz it wasnt working. I think it had blown voice coil. Semi worked then a few days later my stock amplifier from my 08 Mitsubishi lancer gts started smoking from under my seat. I took it out and opened it to find this. Can i take this piece out and fix it with a new one?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Brian .... that is the power amplifier IC
are you good in soldering, for this .... If you have a hot air…. desolder it, note the part no and order replacement.
some idea for you to read……
e.g. troubleshoot, inspect, etc.
http://jestineyong.com/two-ics-burnt-in-...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Brian Mcqueen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 85
