メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
428回答 すべてを表示
Replacing the joystick circuit board in my Xbox One S controller
I've been trying to replace the left joystick on my Xbox One S controller and failing miserably at removing the broken one with the soldering iron. So instead I want to attempt at just replacing the circuit board itself, but before I do I have a few questions.
  1. I'm going to use a circuit board from one of the older controller models for the first gen Xbox One, the one without a 3.5mm headphone jack. Will it be compatible with the Xbox One S controller I'm repairing?
  2. If it works, will the 3.5mm headphone jack still work even though the circuit board is from an older controller model?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Well there’s some good news, and some bad news.
The good news is that it looks as if you can put an original xbox controller board in a new controller body. Although I am not certain. Bad news is that the headphone jack will NOT work, as there is no physical connector to connect to on the older board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
knarrmatt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 623
