メインコンテンツにスキップ
The Canon Selphy CP910 is a compact printer that connects to a camera, computer, and mobile device through a WiFi connection. It is the 34th generation of its kind in the Selphy printer series created by Canon.
16回答 すべてを表示
My Printer says ink is empty but I have a new one installed.
I have an Selphy CP760 and it continually says that I am out of ink even though I have replaced it 2 times.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I can not get my selphy 1300 to reg to my phone I had it for a while put it onto tablet but deleted it off tablet now won't register please help
さんによる
コメントを追加
2件の回答
最も参考になった回答
Since there is not any answers on this forum yet, I decided to answer it since I found the problem. The problem with this error is that the gear which runs the ink cartridge is missing? I took this device completely aprt and did not find any evidence of that gear anywhere. The motor that runs the cartridge is the smaller of the two.. I looked for a replacement gear for this motor but am unable to locate one. I did use this printer so I know it worked before. So that’s it issue solved sort of..
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
How do you get to the gears? I took out 3 screws from bottom but can't get the four tiny ones out!
さんによる
コメントを追加
Same here. Mine is a CP510, but I have seen the internals of the 7XX series and they are the same, and I have the same problem (it was working some time ago, now it’s not and when disassembling, I saw the missing gear). I am trying to look for a solution, but I think the best is to get another, or just forget about it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Terry さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 35
今までの合計 3,884
