メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2397回答 すべてを表示
Touch screen unresponsive after replacement.
I recently replaced my touchscreen on my iPhone 4 following the guide on here since it was dropped and the LCD was fubar. After it's been replaced the LCD works but the touch sensor doesn't work. Is there any reason for this to happen? There were no issues with the removal and installation of the new screen only a couple of the screws were a pain. This is a 16 GB black model.
Any thoughts?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
There can be several issues:
  1. Connector of the touch is not connected properly
  2. Damaged the touch screen during installation (tare the fragile cable apart or maybe installed some screws wrong which caused the cable to get damaged
  3. Screen is DOA
Good luck!
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Who needs luck with a fixed/broken iPhone?
さんによる
コメントを追加
I already had this problem when disassembling the phone. In my case, I just cleaned (with alcohol) the digitalizer contact (both, the one at the PCB and the connector cable itself). After doin' it, I let the phone opened for a while to let the alcohol dry by complete. Touch sensor working fine since then.
As said before, don't forget to take a look at the screws positions. They just can't be mixed up, every screw has its right place.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
kal1982 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 10,619
