LCD cable broken, I need it right
Does anyone have the right one LCD cable?
この質問は役に立ちましたか?
The cable is marked AWM 20624, which seems to specify the type of cable, but not its length or the number of connections. A Google search brings up a number of options - hopefully you can find one in your region. In selecting one there are several things to check:
If you get no luck, try a search for FFC ribbon (FFC is Flat Flexible Cable)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 111
2 件のコメント
It would be very helpful if you could post a photo of the damaged cable. Does it have connectors at both ends, or does the LCD end disappear into the LCD? If the latter it's unlikely that you'd be able to replace just the cable, and instead it'd probably have to be the entire LCD assembly.
Philip Le Riche さんによる
I broke the cable
I set up a picture
ivicagm さんによる
