The side of my cartridge slot is coming off, how do I fix it?
is it really needed? And how can I fix it?
If it’s just the plastic, it shouldn’t really matter.. The cartridges work with or without the cover anyways.. For aesthetic purposes only, it’s up to you if you want to attempt a repair.
このアンサーは役に立ちましたか?
If I were you I may be tempted to plug the area that is crumbling with some tac and then just take care when removing or inserting cartridge. I imagine its only use is to align the cartridge
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 5
過去 30 日: 12
今までの合計 71
1件のコメント
Are you able to elaborate on the issue? Is the plastic part which houses the cartridge broken or is it the actual port itself?
[deleted] さんによる
