メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
No FLASHLIGHT, FLASH, SELFIE, STOPPED CHARGING, NEW BATTERY - 6S PLUS
Hello,
I have a refurbished iPhone 6s Plus and my FLASHLIGHT, CAMERA FLASH, AND SELFIE CAM have NEVER WORKED. NOW RECENTLY, my phone stopped charging! I even put in a brand new battery and still will not charge, so now dead!
I want to fix and do not want to pay someone else to do it. What are the names of the parts that I need to change?
i have ALREADY ordered a “Afeax OEM Original USB Charging Port Dock Connector Flex Cable + Microphone + Headphone Audio Jack Replacement Part for iPhone 6s Plus 5.5" from AMAZON in an attempt to fix the charging issue.
Now what is the name of the part that will fix the FLASHLIGHT, CAMERA FLASH, & SELFIE CAM?
I would appreciate any help that you can provide. I REALLY would like to get the phone fixed ASAP!
Thank you in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
For the flash (same as flashlight) you will need to replace the Power Button Cable assembly and follow this guide. The selfie cam, or FaceTime camera requires that you replace the FaceTime Camera and Sensor Flex. Follow this guide to replace it.
Now, it must be said that it is possible that none of this will solve your problems. If you bought the phone as a refurbished device and it had this many distinct problems, it may be that there is some water damage inside that is causing all of these issues. If that’s the case, then a micro-soldering repair is probably the only solution but that would not be a DIY repair.
Start with the modular repairs and go from there.
iPhone 6s Plus FaceTimeカメラとセンサーアセンブリの画像
ガイド
iPhone 6s Plus のFaceTimeカメラとセンサーアセンブリの交換
難易度:
中レベル
1 - 2 hours
iPhone 6s Plus 電源ボタンケーブルアセンブリの画像
ガイド
iPhone 6s Plusの電源ボタンケーブルアセンブリの交換
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi! Thanks for your answer! So I really need to replace 3 parts? I said “refurbished” but in actuality I bought the parts and put them together myself. 2 of the 3 Phone seork just time, I just don’t know why this one has the light issues. So just to be clear, these are 3 different parts, correct? And are those the “official’ names? I just want to be able to find them on Amazon.
さんによる
コメントを追加
回答を追加する
Jason Kinney さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 131
